Re: Replaced heater core but still leaks!!
Posted: Fri Jun 18, 2010 6:52 pm
by Mr Morlock
if you replaced the core with a new one then it will not be leaking. The leak has to be identified but simple explanation is hose connection??
Posted: Fri Jun 18, 2010 8:26 pm
by ak_perth
Hi flamo,
I dont know what year your car is but I found a pdf which tells you how to remove the dash for 89-93 MX5 if that's any help?
www.miata.net/garage/DashRmv_89_93.pdf
AK
Posted: Sun Jun 20, 2010 3:35 am
by wun911
If your kinda lazy, you can bypass it, and just not have a heater core with flud running in it...
Posted: Mon Jun 21, 2010 5:38 pm
by Benny
If it's leaking in the passenger footwell, it could be the air conditioning as there is a tube there that gets rid of the water that is pulled out of the air.
Lift the carpet on the passenger's footwell, and you should see a plastic tube with a T piece in it.
This tube can come undone, and when it does, it drips water into the footwell.
Posted: Mon Jun 21, 2010 5:58 pm
by greenMachine
It is possible, but not likely, that the new core that you installed is faulty.
Not having used the method that you used, I do not know if this might have happened, but if you had to apply any force to position the core properly, you may have opened up a joint or something similar.
The air-conditioning drain is your best bet, for a cheap fix! How would you feel if that was the problem all along, and you didn't need to replace the heater core? I think that I can guess ...
Posted: Tue Jun 22, 2010 9:27 pm
by Okibi
I've replaced a heater core - I feel your pain.
Posted: Fri Jun 25, 2010 12:56 pm
by NitroDann
I recently had a leaky heater core and i replaced it via the drivers footwell but ended up snapping one of the heater core controls and had to remove the whole dash to plastiweld one tiny broken bit. While i was there i found heaps od dodgy wiring done by previous owners, almost as bad as the stuff i found on the loom at the computer when i wired in my Link.
Posted: Fri Jun 03, 2011 3:36 pm
by jerrah
Would love to know how to replace the heater core without pulling the dash? I did mine about two years ago and fingers crossed it lasts another 20 years.
NitroDann my ECU wiring thankfully is in good shape, but there's a real mess on the drivers side. I took out about a mile of wire that wasn't required. If I was doing it again I would have probably found a unmolested replacement loom.
Posted: Sat Jun 04, 2011 12:54 am
by devski
I got mine replaced by a mechanic under statutory warranty.
For those interested to know, a heater core replacement in an mx5 will set you back around 2 weeks of no car and $980
The two weeks was most likely because I live in tassie and we have very little parts down here!
Posted: Sat Jun 04, 2011 3:30 pm
by NitroDann
jerrah wrote:Would love to know how to replace the heater core without pulling the dash? I did mine about two years ago and fingers crossed it lasts another 20 years.
You look under the middle of the dash looking from the pedals towards the passenger side of the car, the heater core has a plastic cover over it. take it off, undo the clamps. Slide the heater core out.
