REAR HUB BEARING
WASP
REAR HUB BEARING
Postby WASP » Fri Jun 11, 2010 10:16 am
Hi I am about to replace the rear hub bearings, can I reuse the large locating nut's.If you have experience your advice would be welcome
fattima
Re: REAR HUB BEARING
Postby fattima » Fri Jun 11, 2010 11:25 am
I wouldn't, AFAIK they are not designed to be reused. They are available from Mazda and are not expensive.
Juffa
Postby Juffa » Fri Jun 11, 2010 12:55 pm
I have reused mine. Removing the nuts is not something you do often reusing them once should not be a problem.....noting that I am not an engineer, and my advise could kill you.
And I also agree with the response to your question on the big forum.
J
Users browsing this forum: No registered users and 112 guests
