anyone know what brand does a comprehensive kit for the b6 motor.
i want forged pistons, rods, gapless rings, forged gudgeon pins, a metal head gasket. and does anyone have any feedback on tighe cams?
FORGING INTERNALS
- Learner Driver
- Vehicle: NA6 - Turbo
Re: FORGING INTERNALS
I guess it depends how much your willing to spend .. do you want a strong motor on a budget or the muts nuts, best of ever, no returns (which will take masses of boost, shed tyres and gain 11tee mewyen internets points).
- Learner Driver
You might want to check out Flyin Miata:
http://www.flyinmiata.com/index.php?dept=101
Cost a bundle though
Burnished Orange 1991 N/A NA : 130whp on full FCM setup
- de Bounce
If money is no object, there is also Maruha Motors who do a 2.1 lt stroker kit for the BP engine
There is also a write up about the place HERE
No affiliation, just remembered the article!
- lightyear
- Infinity & Beyond
How much boost do you intend on running? If it's only 10psi or less use the stock motor. 10 psi is pretty quick, i don't think many people would need more power. Run some good fuel and keep the timing up.
Users browsing this forum: No registered users and 127 guests
