Just a quick question. Does anyone have the tool for holding the crank while undoing the big nut (simialr to the tool in the service manual) Any chance i could borrow for a week?
if not is there any secrets as to getting the nut off?
Juffa wrote:I found that by putting the car into gear, 5th I believe, then I could undo the nut. Just make sure the rear wheels are on the ground, hand brake is applied and the wheels are chocked so the car can't move. I used a large pry bar over the socket wrench to give me the leverage.
Have you worked out how to stop the cams moving when changing the belt?
J.
