Hi Guys,
I am in a bit of a spot of trouble and I am hoping someone can help me, I was changing my spark plugs today and by accident snapped the end of the sensor that goes into the 2nd spark plug hole. I have taped it up and it seems to be doing fine, however its a short term solution and I need to know where I can buy the new part from and how much? Please excuse my ignorance! Any help will be appreciated! Oh, the car is a 2000 NB8B. Thanks
Broken Spark Plug Sensor
- Learner Driver
- de Bounce
First up, please include your location (User Control Panel - Profile)
Someone local may be able to help you
As you have a NB8B
What part did you actually break
1 Connector
2 High-tension lead
3 Ignition coil
4 Plug cap
5 Spring
Could try a local forum sponsors or Mazda
As you have a NB8B
1 Connector
2 High-tension lead
3 Ignition coil
4 Plug cap
5 Spring
- Learner Driver
Thanks for your reply De bounce, I have broken number 3. The ignition coil, specifically the end of it which connects to high tension lead. Do you know roughly how expensive this part is? And how quickly I can get it?
Thanks.
Thanks.
- de Bounce
jaanh wrote:The ignition coil, specifically the end of it which connects to high tension lead. Do you know roughly how expensive this part is? And how quickly I can get it?
Might be worth seeing if it can be bodgied up.
From there you could try one of the forum sponsors or if someone has a spare.
Then try Mazda, although you might need a chair after they tell you the price
The coil is available new from MX5 Parts (UK) or Rosenthal Mazda Parts (USA)
Good luck
- Learner Driver
Do you think if I glued the piece back together it would work well?
Thanks
Thanks
Worth a try. If it's just the plastic casing which has broken that could well solve the problem...
- Learner Driver
I have glued it and it is working perfectly however I am nervous that the heat will melt and the piece will come apart and I will be in trouble.
- SuperMazdaKart
Users browsing this forum: No registered users and 120 guests
