idle problem
THE FAT STIG
idle problem
Postby THE FAT STIG » Mon Mar 29, 2010 8:04 pm
I have a 1998 nb and the idle jumps around.I believe it is fitted with obd software from the factory and wanted to know if its possible to adjust the idle without pluging the car into a scanner of some type.
idle problem
Postby 93_Clubman » Sat Apr 03, 2010 12:39 pm
I believe so - pretty sure the NB8A ECU clears error codes & resets after you disconect the battery & press the brake pedal a few times. Then take the car for a short run & follow the idle reset procedure in the following:
http://www.miata.net/garage/ignition.html
http://www.miata.net/garage/KnowYourCar/S7_Idle.html
Users browsing this forum: No registered users and 144 guests
