Additive Injection Cleaner
land864
Postby land864 » Tue Mar 16, 2010 5:43 pm
I thought I read on here about a fuel additive injection cleaner.
Techtron?
Any other recommendations
Sailor
Postby Sailor » Tue Mar 16, 2010 9:43 pm
Pull em and have them cleaned or replaced..all else is snake oil
Rob
Postby 93_Clubman » Sat Mar 20, 2010 11:10 am
Pete, Redline SI-1 fuel additive is more expensive at $20 or so, but good stuff:
http://www.redlineoil.com.au/product-in ... ladditives
There's also Subaru Upper Engine Cleaner for about $20, but this is sprayed into top of engine vacuum lines as opposed to being added to fuel:
viewtopic.php?f=29&t=27600
viewtopic.php?f=29&t=36182
http://www.miata.net/garage/tsb/s004_93.html
Will PM you contact details of where you can buy a new set of factory NB8B injectors cheaper than you can get them cleaned for, if/ when you want to go down this track.
owm
Postby owm » Sat Mar 20, 2010 3:46 pm
I use FP60 once a month:
http://lubecontrol.com/fuel.htm
More for preventive maintenance.
Caltex Techron is also good.
Both get glowing endorsements in BITOG.
Burnished Orange 1991 N/A NA : 130whp on full FCM setup
Users browsing this forum: No registered users and 137 guests
