My motor is together finally but have mis placed the oil pickup tube. Will a B6T one fit ok as I have a B6T bottom end I can pull one from?
Thanks,
Will a B6T oil pickup fit a BP motor?
- Vehicle: NA6 - Turbo
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
If you mean the pipe and strainer that drops down from the oil pump then the Mazda parts catalogue lists them with 2 different numbers ...
91-92 B6 is B61P-14-240
95-96 BP is BPE8-14-240
... and the mounting brackets look different in the diagrams. Gaskets are different too.
Yep thats the part im referring to. Thanks magna thats what I was needing to know... Looks like i'll need a new BP oil pick-up.
rxmx,
rxmx,
Users browsing this forum: No registered users and 71 guests
