NA 1.6l 5 speed - type of clutch adjustment ?
not 100% sure but if you talking about making the pedal heavier, you'll have to change to a heavier clutch/pressure plate.
best to buy a Haynes and it will tell you how to adjust clutch pedal free play. You will need also to check if you are losing brake fluid- refer also owners manual.
you can adjust the rod that pushes though the firewall...
you need a 10mm and 12mm spanner...
to make it more "firm" you can bleed it or replace it with ss lines...
every ounce counts
Borked wrote:Is the clutch adjustable via a cable, or is it hydraulic ?
If it's hydraulic, how do I adjust for more pressure ?
It's hydraulic:
1. either drain, flush, refill, & bleed using old slave cylinder; or
2. get a new slave cylinder & refill, & bleed.
Clutch/ brake fluid absorbs water & should be replaced every 2 years for optimal efficiency, so you might find fluid replacement alone helps for a while.
Slave cylinders go after about 10 years, so check it so any sign of fluid leak & then either do 1 or 2 above. If replaced with a lower quality item they go sooner.
Users browsing this forum: No registered users and 30 guests
