Hi Guys
could you help !! mx5 94 cranks but doesn't start had the same problem a few months ago so they replaced the cas . Now have had the cas checked bought a coil pack started once and won;t start again new leads new plugs all done What is next NEW Update car not getting spark no power to ciols
NA 1.8 not starting FIXED
- Bauer
NA 1.8 not starting
when you say "cranks" does that include the camshafts as well as the crankshaft?
cheers
Stu
Stu
- sprx3
NA 1.8 not starting
Bauer wrote:when you say "cranks" does that include the camshafts as well as the crankshaft?
Considering it started once after the change in coil packs i would say yes the cams are turning.......
I take it you are not getting spark & that has been checked?
if not check it & even recheck it
I would also check to see that you are getting fuel,
check silly things like alarm (if you have one) simple check for this is disconnect the main alarm module, this will disable the alarm & if that is the problem the car will start
after you have checked these, report back, & we can get into some more details....
good luck
- Steampunk
NA 1.8 not starting
This is beyond my knowledge, but since no one has mentioned it; fuses?
- sprx3
NA 1.8 not starting
1red5 wrote:This is beyond my knowledge, but since no one has mentioned it; fuses?
again, the car (if i read correctly) has been started once after the breakdown, a fuse would not have allowed that to happen
NA 1.8 not starting
Back again thanks for the replies
ECU now being tested , It does have an alarm but it was disconnected years ago but remains in the car ,I thought maybe it was the alarm but why would it start once when the cas was reinstalled and then again when the coil pack was installed and not again will tell you what happens hope it will be reasonably painless Still think its the cas again !! thanks guys
NA 1.8 not starting
So your 94 NA8 has got fuel, but no spark, & the cams turn when cranked indicating the cam belt is intact?
Could be ECU unless of course it's tested ok since your 2nd last post. Conti had problems with an ECU capacitor leaking over a couple of other components. While he was able to get a new capacitor, the value of the components couldn't be indentified & couldn't be replaced, so he had to get another ECU:
search.php?keywords=ecu&terms=all&author=CONTI&sc=1&sf=all&sk=t&sd=d&sr=topics&st=0&ch=0&t=0&submit=Search
dracomjb had a similar problem which turned out to be something other than ECU:
viewtopic.php?f=29&t=36240
NA 1.8 not starting
93 clubman u are spot on ,Picked it up today leaking capacitor Thanks again for all the help
- Steampunk
Is this in the Tecnhical Guides section? If not, I vote it should.
Users browsing this forum: No registered users and 141 guests
