Hi guys, first post so be gentle.
Bought some Ultrex cam gears off Ebay for my 90 model head i'm doing some work on.
Got the gears delivered no worries but they are are two different types.
Which is exhaust and which is inlet?
No instructions supplied so i fire off an email to Ultrex who tell me they don't know either.
One has dowel pins fitted which i cant figure out what are for.
So far i've figured they can be fitted to either cam.
They both have markings for inlet and exhaust timing.
Anyone have an idea?
Ultrex cam gears
- clubman7
Ultrex cam gears
B6 powered Locost Clubman.
Ultrex cam gears
Believe you'll find thses cam gears are made to be compatible with NA & NB, hence the pickup pins for the NB intake side. Whether they both work across the range of NA & NB engines is another matter. Woo had a problem with his aftermarket cams gears which he needed to slightly modify to work in his NB8A:
http://www.aus-cartalk.com/forum/viewto ... 73&start=0
- clubman7
Ultrex cam gears
Thanks. Will fit gear with pins on intake.
Guess the pins are there for later engines.
Ultrex cam gears
Sounds spot on (NB8A has a cam angle sensor on the front of the cam cover that reads from those lugs on the intake cam).
