Overflowing coolant
- Novice1
Overflowing coolant
Possible causes. Even after a short drive 20 mts at normal driving speeds my car when I stop bubbles over coolant from the reservoir. How much enough to have to use a towel to soak it up.
Thermostat was replaced last year as was water pump. Car is turbocharged, with intercooler.
The dash temperature gauge doesn't give any indication of engine overheating.
Help!
Cheers Novice1
Help!
Cheers Novice1
- Garry
Overflowing coolant
Hows your radiator cap and your head gasket?
- Novice1
Overflowing coolant
Garry wrote:Hows your radiator cap and your head gasket?
Radiator cap is fine. Head gasket hmm, no loss of power noted.
Cheers Novice1
- Uncle Arthur
- Dodgy Award Benefactor
- Location: Doesn't matter where I'm from-it's that your daughter is with me that's the biggest concern :D
Overflowing coolant
Novice1 wrote:Garry wrote:Hows your radiator cap and your head gasket?
Cheers Novice1
You don't have to lose power to have a slight leak of hot boost into the system - enough to pressurise, but not enough to boil..... remembering also the MX5 temp gauge allegedly has a dead spot in the middle.
Overflowing coolant
I'd try a different radiator cap and pray that it solves the problem.
Heat is bad juju hope your head hasn't turned bendy.
Fingers crossed it's not an expensive fix.
- timk
- Novice1
Overflowing coolant
Okibi wrote:I'd try a different radiator cap and pray that it solves the problem.
Its now at the mechanics. May know more tomorrow. I, am praying its something inexpensive.
Cheers Novice1
- Novice1
Overflowing coolant
saboteur wrote:Do the fans kick in when you are sitting in traffic etc?
No idea. I am led to believe that both fans are not always on and to do so would require engine management system to set parameters as to when and at what temperature both fans engage.
Cheers Novice1
- timk
Overflowing coolant
You should be able to do some logic stuff on the E8's A/C fan output, so have it "OR" when the air conditioner is active or the engine temp is above x. It's a pretty standard feature.
- Novice1
Overflowing coolant
saboteur wrote:You should be able to do some logic stuff on the E8's A/C fan output, so have it "OR" when the air conditioner is active or the engine temp is above x. It's a pretty standard feature.
I, am tempted to go with a different tuner, who says he can "unlock" my current tune. Starting to retune from scratch tho would be very costly and I have already spent a small fortune on tuning.
Car as just had retune and its not as good as an early tune.
Turbos...........blahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh.
New sparco seat, new springs, retune and the car rolls over on me, bloody typical:)
Cheers Novice1
- Forced Fives
- Vehicle: 10AE - Turbo
Overflowing coolant
I had the same problem a few weeks ago with my Turbo car. I think the cap was 1.1bar and not very old and it just stopped doing the job and the coolant would mainly overflow once the engine stopped and the cirulation stopped. I relaced the cap with a new 1.3bar cap and no further issues.
Good luck.
Good luck.
10AE Turbo
- Novice1
Overflowing coolant
Forced Fives wrote:I had the same problem a few weeks ago with my Turbo car. I think the cap was 1.1bar and not very old and it just stopped doing the job and the coolant would mainly overflow once the engine stopped and the cirulation stopped. I relaced the cap with a new 1.3bar cap and no further issues.
Good luck.
Well, the good news is that after pressure test found to be normal. No leaks detected. Driving it on the highway several times they were unable to reproduce the car overheating and measured temperatures were normal. They think it may just be the radiator cap...........God I hope so.
Cheers Novice1
- Steampunk
Overflowing coolant
I have a rad cap you can have if you want to try it out and eliminate that as the possible culprit.
- Novice1
Overflowing coolant
1red5 wrote:I have a rad cap you can have if you want to try it out and eliminate that as the possible culprit.
Thanks Andrew. I, did actually look at the radiator cap and cleaned some sludge off it that didn't look like coolant prior to taking it to the mechanics. Other than that no leaks from the cap itself.
If, a mechanic shop can't replace a radiator cap I am in deep sh*t.
Cheers Novice1
Overflowing coolant
Novice1 wrote:I, am tempted to go with a different tuner, who says he can "unlock" my current tune. Starting to retune from scratch tho would be very costly and I have already spent a small fortune on tuning. Car has just had retune and its not as good as an early tune.
Ron, it sounds like you weren't able to resolve that locked ECU issue you had late last year?
