Heatshield
- rossint
Heatshield
Finally got round to making my heatshield to go over the extractors. Hopefully it will lower the temps under the bonnet. I'll put up another pic when it goes on the car.
I used a sheet of this stuff to make it: http://www.aclperformance.com.au/prod_heatshield.htm
- Steampunk
Heatshield
looks good
great product; cheap, easy to form, light but strong, works.
You can touch it after only a few minutes after a spirited drive.
Heatshield
nice - tks for sharing
- TieNN89
- broady
Heatshield
Ross, where'd you get the stuff? Supercheap? And how much did it cost?
人馬一体 NA8
6/5/2010
- rossint
Heatshield
I got it from Supercheap, $50. I used just over half the sheet but you could get 2 out of a sheet if you made it a tad smaller.
It will be bolted onto the 2 existing holes just under the cam cover at the front of the motor, I hope it doesn't vibrate around too much.
I won't have any pics until I get back in about a week or so.
- broady
Heatshield
Went to Stoopercheap today to get some, they didn't have it
人馬一体 NA8
6/5/2010
Heatshield
Repco are their distributors. Check the web site.
- Steampunk
Heatshield
There's also an eBay shop that sells it on occassion. MG Garage (something like that).
Heatshield
looks like tin foil should be lite...
you guys think its worth covering the extractor heat shield with it??
every ounce counts
- Uncle Arthur
- Dodgy Award Benefactor
- Location: Doesn't matter where I'm from-it's that your daughter is with me that's the biggest concern :D
Heatshield
I use the same stuff as the heat shield for my turbo and dump pipe. I haven't had any hoses or plastic melt on the cold side of the shield yet, so perhaps it works afterall.....
- Locutus
Heatshield
wun911 wrote:you guys think its worth covering the extractor heat shield with it??
If you mean the factory heat shield, nope.
- bruce
- Vehicle: NA8 - Turbo
Heatshield
Regards Repco, shop around between the Repco stores as some of their prices vary markedly (eg. one store quoted $180 for a muffler, the second store $250!)
- rossint
Heatshield
Installed...
- Hammer
Users browsing this forum: No registered users and 60 guests
