When should i be chaning my timing belt?
BadBong
Postby BadBong » Fri Dec 04, 2009 7:52 am
Hi guys,
I know the obvious answer is 100,000kms.
My car's only done 60,000kms but it's just ticked over 10 years old... does that warrant a change of timing belt (and accessories)?
My local garage says yes. MX5 specialist says no.
Can someone please enlighten me? Thanks.
Richee
Postby Richee » Fri Dec 04, 2009 10:43 am
I am with the local guy, rubber stuff does perish.
100,000 Km or every 10 years
Who is your MX5 specialist?
Richard
Mazda Tribute - its a boat
PUR157
Postby PUR157 » Sun Dec 06, 2009 2:56 pm
FWIW, our engines are non-interference so a broken timing belt only means stranded car, not destroyed engine.
And from that it's up to you whether or not you want to change it!
Oneness of Man and Machine
wun911
Postby wun911 » Sun Dec 06, 2009 3:34 pm
has anyone here had theirs break before 100 k km but it broke just cause its really old???
every ounce counts
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Sun Dec 06, 2009 4:12 pm
When does your heart tell you that you should change it? :D
Patty
Postby Patty » Mon Dec 07, 2009 1:23 pm
I've had a Pajero io do 120k+ kms before we did the timing belt (not because it failed). Your luck may vary :|
Grace Green NB8A
two40
Postby two40 » Mon Dec 07, 2009 8:15 pm
PUR157 wrote:FWIW, our engines are non-interference so a broken timing belt only means stranded car, not destroyed engine.
Mind elaborating on that a bit? Thanks
George
WTB
- Early NA Radio
- Crash pad for '89 NA
headlightsgoup.com
Uncle Arthur
Postby Uncle Arthur » Mon Dec 07, 2009 11:01 pm
Non interference means no overlap between the intake and exhaust valves and the piston head. In an interference engine, the thing that stops the valves meeting the piston in a mangled mass of metal at 6000rom is the timing chain.
See here:
http://www.autoeducation.com/blog/engin ... d-to-know/
SPy vs. SPy
Postby SPy vs. SPy » Tue Dec 08, 2009 12:05 am
The manual says every 100000 kilometres doesn't say anything about time.
I'd get the water pump inspected for any leakage, if it is, then do the lot together.
Failure to proceed may sound fairly simple until you factor in where it fails to proceed. A 1000 kilometres from home can end up an expensive 1000 kilometres from home, likewise in the middle of peak hour traffic with road works thrown in.
Postby 93_Clubman » Thu Dec 10, 2009 12:19 am
BadBong wrote:I know the obvious answer is 100,000kms. My car's only done 60,000kms but it's just ticked over 10 years old... does that warrant a change of timing belt (and accessories)? My local garage says yes. MX5 specialist says no. Can someone please enlighten me?
Here's some discussion from a few years ago:
viewtopic.php?f=29&t=24111
BadBong
Postby BadBong » Thu Dec 10, 2009 6:00 am
thanks mate, looks like it's a yes.
Postby bruce » Thu Dec 10, 2009 10:46 am
To add my 2c, I would say no, leave it. Ten years is nothing. I've never heard of a timing belt go in a 5.
Postby 93_Clubman » Thu Dec 10, 2009 5:09 pm
BadBong wrote:thanks mate, looks like it's a yes.
Ultimately it's your call - we can only provide a range of views.
I've also not heard of one breaking on an older low km car, but I can't say it won't happen. If you're prepared to risk being stranded, which would depend on the driving you do, then it's a no...
