Yeah you go and buy a 1.6 flywheel and a 1.6 clutch and your good to go.
The teeth line up the same clutch alignment tool is used for both the 1.8 and 1.6 clutch.
Oh btw 1.6 and the 1.8 flywheel have the same diameter; but 1.6 is a more "traditional flywheel" so it has slighly less peripheral rotational mass (where it counts the most)
And yeah lots of fun to drive once installed.
NA6 Clutch and flywheel , will it fit on an NA8 ??
every ounce counts
