Power Steering heading south?
MX5CHIC
Postby MX5CHIC » Wed Nov 11, 2009 12:55 pm
I need advice on my NB Power Steering - I have a "groaning" noise when the car is first started up but only when I move the steering wheel, after 5-10 minutes it is all fine and quiet.
Steering feels normal even when it is making the noise, I first noticed it around 3-4 months back so I completely drained and refilled the power steering fluid which has made no difference at all.
Any suggestions ?
Postby bruce » Wed Nov 11, 2009 1:30 pm
Check the level again? Is there a leak? In the past on other cars, if there is any noise it is due to low fluid.
MX5CHIC
Postby MX5CHIC » Wed Nov 11, 2009 2:26 pm
When it began making noise I noticed the fluid level was a little low, since flushing and refilling, the level has remained perfect and no leaking evident .... :?
Postby hks_kansei » Wed Nov 11, 2009 3:24 pm
random guess here.
maybe it sucked some air into the pipes? it grinds when it hits an air pocket, and is quiet after it's built some pressure and pushed the air somewhere.
Postby manga_blue » Wed Nov 11, 2009 10:16 pm
Did you bleed the steering after re-filling it? From memory it's 3 full cycles lock-to-lock with the engine idling.
