nb8a air con belt
- 16bit
nb8a air con belt
hey guys just wondering if the air con belt runs off the power steering too? My air con does not work and was wondering if I could remove the belt.
nb8a air con belt
Yes they do share the same belt, so unfortunately no you wont be able to remove it and still have power steering.....
- 16bit
nb8a air con belt
i assume its a massive pain in the arse to change it over yourself too?
- Patty
nb8a air con belt
I think wun removed parts of his air con and also bought a belt which just drove the P/S.
EDIT: Here.
EDIT: Here.
Grace Green NB8A
- bruce
- Vehicle: NA8 - Turbo
nb8a air con belt
You just need a shorter belt. Guess it is the same belt from a model without AC but has PS. Don't know if it is an easy job swapping.
nb8a air con belt
yeah its easy need only 12 and 14 mm socket with a mini extension...
every ounce counts
