Recomend a trickle charger for spare battery...
wun911
Postby wun911 » Tue Oct 27, 2009 8:05 pm
Im looking at buying a trickle charger for a spare battery.
Can you leave it pluged there forever?? Any pros and cons what should I look for etc?
every ounce counts
Postby Hammer » Tue Oct 27, 2009 9:18 pm
I have one that is a Projecta brand. I got it from Battery World 4-5yrs ago. It was about $50ish if I remember right.
It comes with a lead that connects to the battery which has a quick release plug that connects to the trickle charge unit and the plug to the power point.
MX5CHIC
Postby MX5CHIC » Tue Oct 27, 2009 9:56 pm
I bought a solar charger from Repco a few years ago for $29.95 - I have had it connected to a spare battery at my parents home for the past 2 years with the solar panel (around the size of a standard number plate) sitting in the garage window catching the afternoon sun.
I use it to start up my old Alfa Romeo every now and then and it is always perfectly topped up.
Postby Okibi » Wed Oct 28, 2009 12:45 am
Yup I got one of those for the 121 the other week, planning on getting one for the spitfire and the bike.
I have a one of these I swap between cars to keep the batteries topped up
http://www.projecta.com.au/catalogue/cid/3/asset_id/15
They come with one vehicle harness as well as alligator clips, I ordered 2 more harnesses but the quality is crap and I made my own.
For example I have a plug next to the licence plate on the motorbike so I don't have to take the seat off to charge the battery.
wun911
Postby wun911 » Wed Oct 28, 2009 9:08 am
There is nothing wrong with leaving the miata battery on a tricke charger being dry cell and all???
Yeah I like the solar power idea, Im not going to be using the stock battery for a while I got a light weight one...
every ounce counts
Postby bruce » Fri Oct 30, 2009 1:27 pm
It's not a dry cell battery, just a sealed cell battery.
As long as the charger can sense the battery level and not overcharge it, it should be OK.
corners
Vehicle: ND - Supercharged
Postby corners » Thu Nov 12, 2009 11:39 pm
Ctek make battery chargers that are very good for trickle charging.
They are however expensive....
https://www.shopatron.com/products/prod ... 05.0.0.0.0
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Fri Nov 13, 2009 10:09 am
I bought a Supercheap SCA branded microprocessor controlled charger yesterday for $35.
