Sandwich Plate
Robbo
Vehicle: 10AE
Sandwich Plate
Postby Robbo » Fri Oct 23, 2009 4:37 pm
Hi all,
Have just fitted a sandwich plate to my NB. Decided as you do to start the engine to see if any leaks. After a minute or so a leak started but I cannot see (feel) where it is coming from. Has anyone had a similar problem? Is there a fix. Any suggestions welcome. :!: :idea:
RG.net
Sandwich Plate
Postby RG.net » Fri Oct 23, 2009 6:06 pm
How did you install it?
Did you use teflon tape?
Block up the remaining holes in the sandwich plate?
Tighten the sh*t out of the oil filter adaptor?
If you answer no to any of these, it will most likely be the problem.
Robbo
Vehicle: 10AE
Sandwich Plate
Postby Robbo » Sat Oct 24, 2009 9:36 am
Thanks for that. The only thing I didn't do is use teflon tape. All the other 3 non used holes in the plate were blocked with the supplied bolts. I tightened the crap out of the bolt that holds the plate in place plus the filter when I fitted that. Bugger of a place to put the filter. So it is back to rip it out today and fix the sucker.
RG.net
Sandwich Plate
Postby RG.net » Sat Oct 24, 2009 11:42 am
ahk, i used teflon tape on all the bolts going into the sandwich plate (sensors included). The only thing i didn't teflon was the thread on the block.
Let us know how it goes.
Babalouie
godfather of saké
Sandwich Plate
Postby Babalouie » Sat Oct 24, 2009 1:22 pm
Is it new or second hand?
I had a second handy one once and the rubber o-ring seal between the sandwich plate and block was old and hard. Looked ok but leaked until I could get a fresh new one in.
Temporary fix was to fit a rubber seal from an oil filter (was same diameter) which does work if you're in a jam, but apparently that's not what you're meant to use since the groove in the plate isn't square.
Robbo
Vehicle: 10AE
Sandwich Plate
Postby Robbo » Sat Oct 24, 2009 4:22 pm
Hi All,
Well tried again with no luck. Still leaked even after putting teflon tape on the thread that holds the plate on. Have also used teflon tape on the sensor plus the other bolt holes. Upon looking at the plate I think I will need a washer (fibre) between the plate and the bolt attachment that holds fast to the block. I am not sure if the leak is coming from where the rubber seal is or elsewhere. I might try some gasket goo there. I will try everything until I fix this sucker. And yes I did tighten the sh*t out of everything I could. Maybe 3rd time lucky :?:
