timing belt and water pump query
Posted: Fri Oct 23, 2009 9:19 am
If it's time for a belt change, then it's time for a pump change.
The pump will leak sooner or later, and because you need to undo the belts to remove and install it, why not take a pre-emptive (did I spell that right?) step and fix it now before it becomes a problem.
