timing belt and water pump query
Steampunk
Postby Steampunk » Fri Oct 23, 2009 9:19 am
If it's time for a belt change, then it's time for a pump change.
The pump will leak sooner or later, and because you need to undo the belts to remove and install it, why not take a pre-emptive (did I spell that right?) step and fix it now before it becomes a problem.
wun911
Postby wun911 » Fri Oct 23, 2009 11:18 am
My pump lasted 200 k km and was still good and working without leaks, but I decided to change it, takes about an extra hour or so ontop of your T belt change.
The seals they recomend the drill and screw method (look how deep the new seal is (you dont have to drill very far)
every ounce counts
jules
Guitar Hero
Postby jules » Fri Oct 23, 2009 11:55 am
Yes, do it and get a genuine unit as well. You don't want to be going back in there in 6 months time.
Jules
