Stupid PPF Bolts!
daffyflyer
Stupid PPF Bolts!
Postby daffyflyer » Thu Sep 17, 2009 3:26 pm
Why do my PPF bolts keep falling off! :evil:
Heard some clattering noises last night, and when i got home it appears the rearmost bolt holding the PPF to the diff had fallen out.. not sure why, i seem to remember doing them up spectacularly tight
Any ideas? Loctite? :P
Also if you are reading this russelb, will be around to pick up another ppf bolt from you tommorow (i swear im your biggest customer for these things!)
Developing a Car Industry Game - Visit www.automationgame.com
White 1994 MX5 Clubman - Carco Built NA Motor - 101kw ATW @ 7500rpm
AJ
Stupid PPF Bolts!
Postby AJ » Thu Sep 17, 2009 3:29 pm
"spectacularly tight" huh??.........probably overdone it & stretched the thread..........toss 'em away & bang some new ones in, using a torque wrench to specifications...... :wink:
XMX5 Rogues
Stupid PPF Bolts!
Postby bruce » Thu Sep 17, 2009 5:18 pm
Ask someone who should know - find out the torque and the right loctite to use.
wun911
Stupid PPF Bolts!
Postby wun911 » Thu Sep 17, 2009 7:04 pm
I thought the torque settings on those were like 120 pounds... (thats kinda tight) And i Also thread locked them.
The PPF bolts that go though the diff are torqued > 200 pounds (thats kinda super tight)...
every ounce counts
16bit
Vehicle: NB8A - Supercharged
Stupid PPF Bolts!
Postby 16bit » Thu Sep 17, 2009 7:57 pm
BF cheater bar would be needed for that.
Garry
Stupid PPF Bolts!
Postby Garry » Thu Sep 17, 2009 8:07 pm
What AJ said. New bolts torqued to the correct specification. If you over torque them you run the risk of cracking the PPF which is what happened in my car.
Fuzzlet
Stupid PPF Bolts!
Postby Fuzzlet » Thu Sep 17, 2009 8:12 pm
Thats not a big silver bolt around 25cm long? I cant remember just how many I had to replace in that damn thing...
daffyflyer
Stupid PPF Bolts!
Postby daffyflyer » Thu Sep 17, 2009 8:15 pm
Fuzzlet wrote:Thats not a big silver bolt around 25cm long? I cant remember just how many I had to replace in that damn thing...
Thats the one!
Managed to avert buying a new one, went to the intersection at the end of my street where it made the noise and picked it up.
Too much of a bitch for me to bother putting it back in though so carco will be called upon :D
Fuzzlet
Stupid PPF Bolts!
Postby Fuzzlet » Thu Sep 17, 2009 9:19 pm
I'm surprised it lasted this long....we absolutely coated it in locktight, cos even torquing it to the right spec it would still undo...
Stupid PPF Bolts!
Postby manga_blue » Fri Sep 18, 2009 11:09 am
Correct torque for those bolts is 87 - 91 ft-lb. If you did 120 ft-lb then you've probably stripped them. They're only 12mm bolts f'crissake.
daffyflyer
Stupid PPF Bolts!
Postby daffyflyer » Fri Sep 18, 2009 11:21 am
Fuzzlet wrote:I'm surprised it lasted this long....we absolutely coated it in locktight, cos even torquing it to the right spec it would still undo...
We didn't think of that! :P
daffyflyer
Stupid PPF Bolts! - Fixed and Drives better than ever!
Postby daffyflyer » Fri Sep 18, 2009 9:15 pm
Yay, Carco fixed the bolt along with a bunch of other stuff like a broken swaybar link...
Handles very noticeably better, my missus said she could tell even in the carpark.
Feels flatter, stiffer and doesn't creak over bumps anymore!
Thanks russell, I know it must drive you mental having to work on anything i have touched, but at least my screw ups keep me coming back :P
MXkal
Stupid PPF Bolts!
Postby MXkal » Sat Sep 19, 2009 9:34 pm
I had a 4 hour loctite conference at work last week about all their products and the different types of applications, For applications that have minimal metal ions such as stainless,alloy, and even galvanised steel a primer (loctite 7471)will be needed to actually cure the loctite solution otherwise it just wont work as it should.
Overkill is an understatement.
Fuzzlet
Stupid PPF Bolts!
Postby Fuzzlet » Sun Sep 20, 2009 5:31 pm
Haha that creak/squeak noise was from the lower bush on the front shocks...Coating them in silicone spray generally shut them up
daffyflyer
Stupid PPF Bolts!
Postby daffyflyer » Tue Sep 22, 2009 11:00 am
Fuzzlet wrote:Haha that creak/squeak noise was from the lower bush on the front shocks...Coating them in silicone spray generally shut them up
Oh yeah, it still creaks from there lol :P
