Sorry, this is not MX-5 related but I really admire the infinite knowledge base this forum holds. I'm hoping someone can help me with this problem. My Sierra has an ultra small micro leak on the bottom of the tank. It's not drippling or anything, more of a dark patch where the fuel is getting through and evaporating. Without having to remove the tank and getting it welded, are there any compounds that can be applied externally to seal the leak? The hole would be less than the size of a pin head.
Jimmy.
Best way to patch up a micro leak in the fuel tank
- Jimmy
jb weld or quiksteel. looking at my quiksteel packet here, it says automobile petrol tanks,radiators,blocks,intake manifolds etc...
- Jimmy
This stuff is totally cool
http://www.por15.com/FUEL-TANK-REPAIR-K ... info/FTRK/
used it before, empty the tank, pour it in, move it around, leave it to dry and you have a new eppoxi tank inside the metal. It works
Si
Si
NA6 B6T
- Benny
Obviously the tank in your Sierra is on its last legs, and even if you fix this leak, more will develop shortly.
It's a bit like a frayed piece of clothing, once it starts to fray, it won't be long for the rest of it to fall apart.
Having even a micro leak in a fuel tank can be disasterous, as anyone walking by it with a lit cigarette could set it off, and fumes WILL make their way into the cabin.
