Clutch/Gearbox grinding problem... **video up**
green_comet
Car Detailing Guru
Postby green_comet » Sat Aug 22, 2009 2:48 pm
Hey guys,
Im having a problem with my Clubman, its a harsh grinding sound and vibration when the clutch pedal is pushed down. It started thismorning on the way to work, and seems to go away after driving the car for about 10min. It has never done this before, and I find it weird that it would happen all of a sudden. I jacked the car up and had a look around, the oil in the gearbox is fine, and there is plenty of fluid in the clutch reservoir. :?
I took a video for you guys, you can hear the grinding when I press the clutch, and when putting the car into gear.
Im thinking it might be the thrust bearing, but I dont know for sure. If anyone could offer some help or info on what might be causing this grinding that would be great.
Ryan
bensale
Postby bensale » Sat Aug 22, 2009 3:13 pm
I think its the throw out bearing too, my car makes the same noise only a lot quieter.
www.othersideproductions.com
Postby 93_Clubman » Sat Aug 22, 2009 3:24 pm
sounds like thrust bearing, but may be check the clutch slave cylinder rod is actuating sufficiently when the clutch is depressed, even though there appears to be plenty of fluid in the reservoir.
Sailor
Postby Sailor » Sat Aug 22, 2009 4:20 pm
Throwout or pilot bearing..
Rob
green_comet
Car Detailing Guru
Postby green_comet » Sat Aug 22, 2009 4:47 pm
Thanks for the help guys, I will check out the slave cylinder rod when I get a spare person to push the clutch in for me. I dont think thats the problem though, it looks like im going to have to drop the box out and fix it up, this seems like a good excuse to change the clutch while im at it, and also slap in a aftermarket alloy flywheel. :lol:
I think ill order this kit, after I confirm if its the thrust bearing or not.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=160266833745&viewitem=&sspagename=STRK%3AMEWAX%3AIT
(yes im going to install the smaller 1.6 gear)
Dodgy day anyone?? Freddy?? :lol:
wun911
Postby wun911 » Sat Aug 22, 2009 5:17 pm
thats cheap and the aud is better now days...
every ounce counts
green_comet
Car Detailing Guru
Postby green_comet » Mon Aug 24, 2009 1:29 pm
Well I just got off the phone with Race Brakes, I ordered myself an Xtreme HD clutch kit. I was going to get an Exedy HD kit, but I did a bit of reading and found the Xtreme HD clutch kits had alot of good reviews, and they were quite cheaper compared to the Exedy HD kit. Cost me $245 all up for the kit, and they will have it for me tomorrow.
Organic Disc and Heavy Duty Cover
Specifications : Clamp Load = 630Kg
I didnt go with the ebay clutch/flywheel kit I listed above, because I wanted a better than oem clutch, soo I have ordered just the 8lb 1.6 Fidanza flywheel. Cost me $470 delivered from USA. Soo all up everything has cost $715 which im pretty happy with, im sure ill still have to get a few other bits and pieces though (spigot bearing, clutch alignment tool, rear main engine seal, gaskets etc).
Freddys gonna hate me coz I didnt go with the 1 piece chromoly flywheel. :lol:
This is it here, I should have it in about a week.
d-mag
Road Track Rally
Vehicle: ND - Turbo
Postby d-mag » Mon Aug 24, 2009 1:46 pm
Are you fitting it yourself Ryan?
MX5 Wanted. SE or NC (forced induction preferred :twisted: )
green_comet
Car Detailing Guru
Postby green_comet » Mon Aug 24, 2009 2:28 pm
Im going to try to, Im kinda broke now seeing as I wasnt expecting my clutch to pack it in, and I have rego to pay by the end of the month. :? Im not really up for paying more cash to get it all fitted. Know anyone with a hoist we can use Daz??
d-mag
Road Track Rally
Vehicle: ND - Turbo
Postby d-mag » Mon Aug 24, 2009 2:37 pm
I've only got a 'Maori Hoist' mate (Read: a forklift on either side of the car :lol: ).
green_comet
Car Detailing Guru
Postby green_comet » Mon Aug 24, 2009 3:00 pm
:lol:
Thats almost too dodgy for a dodgy day....almost! :lol:
meanmx
Postby meanmx » Mon Aug 24, 2009 6:12 pm
d-mag wrote:I've only got a 'Maori Hoist' mate (Read: a forklift on either side of the car :lol: ).
I'll drive the forklift Darrin :lol: :lol:
Ben
2014 VW Mk7 Golf R
wun911
Postby wun911 » Mon Aug 24, 2009 8:12 pm
I still have the giant ramps, a can of coke and a couple of dogs is all that is required....
oh and you have to be able to "bench" around 70 kg...
every ounce counts
green_comet
Car Detailing Guru
Postby green_comet » Mon Aug 24, 2009 8:37 pm
So I can come round for a wun/green_comet take on clutch/flywheel? You sure FFG wont get jealous? :lol: Ill gladly supply food, and drinks whatever you like. Plus it would be great having someone who has done this job before to help out. FFG and Ben would be more than welcome to attend, as im really not feeling confident enough to tackle this job alone.
Fatty
Postby Fatty » Mon Aug 24, 2009 8:55 pm
sounds like fun , any chance it'll be this weekend or the next? i leave for europe the week after that.
