When Your Engine Eats # 4 Rod Cap & Piston
Posted: Sat Aug 01, 2009 4:12 pm
by wtnmiatas
This is what it looks like. Got the piston & bent the rod & cap up like a pretzel. Happen on my 99 Miata.
Posted: Sat Aug 01, 2009 4:33 pm
by Ando
Eeeek!!!!
Man, what a mess. I'm assuming the car stopped dead in it's tracks?
Posted: Sat Aug 01, 2009 4:54 pm
by wtnmiatas
Ando wrote:Eeeek!!!!
Was rolling down the interstate 40 here about 70mph. Heard a bang & pop clutch it & pop it out of gear & costed over to the side of the interstate with a dead engine. Hour later on the hook haveing it taken home.$$$ Was hoping it was the timming belt but she was locked up. Pulled the plugs & # 4 plug gap was hammer closed. So I pulled the head & saw what made the bang & pop.$$$$$$$
Posted: Sat Aug 01, 2009 6:02 pm
by JBT
Is this the result of the dreaded #4 thrust bearing failure problem with the 99 model?
Posted: Sat Aug 01, 2009 6:47 pm
by wtnmiatas
JBT wrote:Is this the result of the dreaded #4 thrust bearing failure problem with the 99 model?
I dont think so it had over 143,000 miles on it. I found one of the #4 rod bolt nuts in the bottom of the oil pan. Think it came loose & cause the crank bearing to spin an then the nut came all the way off. The thrust bearing wasnt beat up etc. The head - block & crank are ok.
Posted: Mon Aug 03, 2009 12:20 pm
by Benny
You're really lucky it didn't ventilate the block!
I'd be checking the condition of the bore in #4 very closely though.
Posted: Mon Aug 03, 2009 7:38 pm
by wtnmiatas
Benny wrote:You're really lucky it didn't ventilate the block!
There was a small nick about a inch long in the bottom of cylinder where the rings dont go down that far. 4 or so up & down passes with a engine cylinder honer cleaned it up.
Posted: Tue Aug 04, 2009 3:57 pm
by Benny
Thank goodness you can save it then.
Might be a very good excuse to bore it out a little.
