Torsen owners
- Regie
- Vehicle: NC - V8
Torsen owners
I'm getting my torsen installed tomrrow. Just wondering if there is any special oil to put in there? Or just the STD LSD will do?
- lil red rocket
- Vehicle: NA6 - Turbo
Torsen owners
Talk to Danny at MX-5 plus SERVICE . He has intalled one also. He should know
phone (07) 3265 1112
or email service@mx5plus.com.au.
042 9999 485
Regards Brian H
lil red rocket aka blue chilli
042 9999 485
Regards Brian H
[color=#BF00FF]I like it! I like it a LOT!
http://www.cardomain.com/ride/3368773/3
- Hellmun
- Vehicle: NB8B - Turbo
Torsen owners
It's standard gear oil. No friction modifiers needed like in a clutch pack diff. It'll be the same oil you run in an open diff which is 75/90 from memory.
- sliq
- jerrah
- JBT
Torsen owners
Just use the same oil as recommended for the open diff and change it at the same intervals.
- Steampunk
Torsen owners
JBT wrote:Just use the same oil as recommended for the open diff and change it at the same intervals.
ditto
- Regie
- Vehicle: NC - V8
Torsen owners
sweet thanks!!
im looking forward to some sideways action
- StanTheMan
Torsen owners
the torsen is a fabulous mod. I love mine
- philz
- Wheel guru
Torsen which one?
Well anyways since the question has been answered, I will hijack it.
Which torsen/ratio would you guys recommend for nb8a standard 5 speed?
- StanTheMan
- Szemen
Torsen owners
Might as well put my question here then...How do you confirm you have an LSD? Peer in during a diff oil change?
- Steampunk
Torsen owners
Szemen wrote:Might as well put my question here then...How do you confirm you have an LSD? Peer in during a diff oil change?
Park one rear wheel on grass/dirt/loose surface and the other on clean bitumen.
Rev her up, dump the clutch;
- if the wheel that is on the loose surface continues to spin, then you have an open.
- " " " " " " " " " stops spinning within a split second and the wheel on bitumen gets more drive (may start spinning also) then you have LSD.
Torsen owners
Jacking the rear of the car and rotating one wheel...If the opposite rotates same direction you 'may' have an LSD.
Does this work with the Torsen?
Rob
- JBT
Torsen owners
The tests above won't necessarily work on a Torsen diff because, if one wheel loses traction, it will behave the same as an open diff. Clicky
