removing AFM on NB
Posted: Mon Jul 13, 2009 2:01 pm
by 16bit
Hello all I was wondering what would need to be done to be able to remove the AFM on my 98 nb. I have a piggy back computer (xede) which i would think would be able to handle it. Would I need another sensor of sorts? I would like to get rid of it for flow reasons mainly. Has anyone done this and if so how has driveability been effected if at all? Any help or advice would be greatly appreciated.
removing AFM on NB
Posted: Mon Jul 13, 2009 2:32 pm
by NMX516
You would need to use a MAP sensor instead, which will require after market ECU. The std afm causes three parts of f-all restriction, so unless you have a much better excuse for needing an after market ECU, save your dollars.
removing AFM on NB
Posted: Mon Jul 13, 2009 2:37 pm
by Juffa
Damn...was too slow in typing.... what he said ^
removing AFM on NB
Posted: Mon Jul 13, 2009 3:07 pm
by 16bit
can't do it with xede i have found oh well.
removing AFM on NB
Posted: Mon Jul 13, 2009 8:37 pm
by manga_blue
NMX516 wrote:You would need to use a MAP sensor instead, which will require after market ECU. The std afm causes three parts of f-all restriction, so unless you have a much better excuse for needing an after market ECU, save your dollars.
So, does the NB8A MAF flow any better than the NA8 one? The NA8 one looks restrictive - it seems way smaller in area than the throttle body.
removing AFM on NB
Posted: Tue Jul 14, 2009 12:20 am
by NMX516
I'm fairly certain that the NA8 and NB ones are the same.
removing AFM on NB
Posted: Tue Jul 14, 2009 4:03 pm
by RG.net
NMX516 wrote:I'm fairly certain that the NA8 and NB ones are the same.
Really? i thought they looked a little different =/
removing AFM on NB
Posted: Tue Jul 14, 2009 4:24 pm
by Steampunk
MXHEVN wrote:NMX516 wrote:I'm fairly certain that the NA8 and NB ones are the same.
They are.
Inside the NA8 is a single column with a hole/cylinder in the centre that houses the wire-air temperature sensor.
Inside the NB's, they have a grid and I'm not sure where the temperature sensor is in there, but probably in the middle as well.
removing AFM on NB
Posted: Tue Jul 14, 2009 7:12 pm
by NMX516
Well there you go....
Lucky I wasn't 100% certain, only fairly certain
removing AFM on NB
Posted: Sat Jul 25, 2009 4:35 pm
by Regie
1red5 wrote:MXHEVN wrote:NMX516 wrote:I'm fairly certain that the NA8 and NB ones are the same.
They are.
the NB temp sensor it attached to the airbox itself
removing AFM on NB
Posted: Sat Jul 25, 2009 6:24 pm
by AB7
Yes, NB temp sensor is near the airbox. I got hydra EMS & moved mine closer to TB since I ditched the AFM.
