6speed vs 5speed
16bit
Vehicle: NB8A - Supercharged
6speed vs 5speed
Postby 16bit » Thu Jul 09, 2009 2:32 pm
just wondering if the clutch and flywheels are the same in the 6 speed and 5 speed boxes? I would assume so but just checking.
mx52nv
Purple Porsche Eater
6speed vs 5speed
Postby mx52nv » Thu Jul 09, 2009 3:26 pm
16bit,
Yes, you can fit a BP flywheel/clutch to a 5 speed or 6 speed gearbox.
The flywheel/clutch is specific to the engine (i.e. B6/BP) not the gearbox for NAs or NBs.
Hope this helps. :wink:
Les
Boags
6speed vs 5speed
Postby Boags » Thu Jul 09, 2009 3:43 pm
All BP engines take the same diameter clutch from factory, but the flywheels are lighter as the models progress, AFAIK.
I'm not 100% about NA8 - NB8A, but I know there is a difference between NB8B and NB8A.
HTH.
16bit
6speed vs 5speed
Postby 16bit » Thu Jul 09, 2009 4:45 pm
excellent.
Matty
6speed vs 5speed
Postby Matty » Thu Jul 09, 2009 10:30 pm
NA8 and NB8 flywheels are slightly different I believe.
wun911
6speed vs 5speed
Postby wun911 » Thu Jul 09, 2009 11:51 pm
I think they are different but you get the clutch to match and its all good, no matter what gear box you have.
every ounce counts
