A couple of Questions to maybe the race guys
I am replacing the Turbo engine in LowMiata AKA Ryan Middleton's Evil5
I have a used B6D 1600 LNC Engine to be rebuilt.
What I want to build is a reliable Turbo engine used for Street and Track
- running up to about 12 lb boost expecting about 200 RWHP
The new engine goes something like this:
Ground, Crack tested, shot peebed and titrided crank
new pistons, rods, valves, double valve springs, bearings, seals, gaskets, water pump, timing belt, ARP Head and rod bolts etc.
Port and polished head
ground cams
Question 1: will a 1800 block fit a 1600 head?
Question 2: are 1800 rods the same as 1600 rods
Question 3: Has anyone used BELFAB RACING PRODUCTS ie pistons and rods or full rebuild kit?
They look good on www.belfabracing.com and the prices is just over AUS$2000 for forged pistons and rods, springs, valves bearings and gaskets etc - WORTH A LOOK AT!!!!
regards
Lil Red rocket / Blue Chilli
Rebuilding an NA Turbo 1600
- lil red rocket
- Vehicle: NA6 - Turbo
[color=#BF00FF]I like it! I like it a LOT!
http://www.cardomain.com/ride/3368773/3
- adamjp
No - the bore is larger, making the piston centres further apart.lil red rocket wrote:Question 1: will a 1800 block fit a 1600 head?
Yes. They simply changed the bore, not the stroke.lil red rocket wrote:Question 2: are 1800 rods the same as 1600 rods
Yes - Pistons, valves and valve springs. Good reports on the rods, but I built a NA motor and wanted the lightest rods I could find. Belfab rods seem to have a good rep for a turbo engine.lil red rocket wrote:Question 3: Has anyone used BELFAB RACING PRODUCTS ie pistons and rods or full rebuild kit?
The water pump they sent me was wrong. The gasket kit was OK, but not as good as what I bought locally last time.
Adam
- Russellb
- RIP Nov 2014
BelFab Rod and super tech pistons are the go
capable for over 250 RWKW
The Valve springs and Valve's are the ones FM sell
all these parts are in Turbo Boy and Girl
Money well worth spending
Not the Bearing are wrong get ACL race series in AUS
Also Balance all parts Crank,Pistons ECT and match weight pairs of Pistons Rods an Wrist pins
This is were the time and money goes for a Good engine
My ClubmanRebuild
MX5 SE Rally car is HERE
- jules
- Guitar Hero
I thought the current engine in that car was getting pretty good HP?
Jules
Jules
- JBT
jules wrote:I thought the current engine in that car was getting pretty goof HP?
Maybe 150,000km ago
- Jeo
Two threads for the same question is typically frowned upon.
- Novice1
Just a word of caution when fitting an EMS make sure the tuner doesn't password protect his work.
You want to have free access to your tuning maps.
Cheers Novice1
Cheers Novice1
- lil red rocket
It looks like I'm going down the Belfab road for pistons, rods, valves, springs and gaskets. I'll let you all know the price landed.
Who should I use locally in (Brizvegas) for Turbo / MicroTech ECU tuner - MazFix ???
Who's had a good experience?
