SE Head on NA 1.8
irwin83r
SE Head on NA 1.8
Postby irwin83r » Thu Jun 18, 2009 6:51 pm
head should go on no worries.. space might be tight in the engine bay though
evil_weevil
SE Head on NA 1.8
Postby evil_weevil » Thu Jun 18, 2009 10:30 pm
What sort of gains would you be looking at powwer/torque wise?
And what sort of cost to change heads on an NA8? would it be worth it over, say....changing cams in standard head?
Chris
viewtopic.php?f=73&t=62834
Russellb
RIP Nov 2014
SE Head on NA 1.8
Postby Russellb » Thu Jun 18, 2009 10:48 pm
evil_weevil wrote:What sort of gains would you be looking at powwer/torque wise?
Chris
Will fit without a problem
Power wise ? with the Link ECU should make 140 RW KW with out a drama
This is what my NA8 Made unintercooled
with an AVO manifold and Autronic SMC
Intake temps were over 100 Deg C at the track
My ClubmanRebuild
MX5 SE Rally car is HERE :)
16bit
Vehicle: NB8A - Supercharged
SE Head on NA 1.8
Postby 16bit » Thu Jun 18, 2009 10:56 pm
i think the combustion chamber volume goes up by almost a third with nb8a on head. i am sure one of the members who have build a head could verify. you should be able to flow more with the newer head whether that results in power on a forced induction application on a streetable scale I am not sure. You can get away with quite a bit more 'inefficiency' in forced induction applications than you can in na applications. it would probably come down to the variables between combustion chamber pressure and volume that would yield the most favorable conditions for power. this gets into the area of danny territory i think.
evil_weevil
SE Head on NA 1.8
Postby evil_weevil » Fri Jun 19, 2009 8:21 pm
So for a non turbo, na8 with basic mods - is it worth doing the head change or staying with standard head on na8 and just upgrading cams?
Steampunk
SE Head on NA 1.8
Postby Steampunk » Fri Jun 19, 2009 11:38 pm
send a PM and wake-up tinscfi over in WA.
He knows a thing or three
