I cant install engine mounts
wun911
Postby wun911 » Sat Jun 06, 2009 5:25 pm
cant install engine mounts??
I have unbolted 4 x 14mm nuts that hold the engin to the mounts and the 1x14mm nut that holds the mouts the the sub frame.
It jiggles it wiggles it does not come out?
I cant get the angle grinder in there to cut the the old engine mout out :cry:
Im a little lost Ive tried a crow bar and a hammer but to no avail....
Do you have to do both sides at the same time, Im trying to do the passenger's side first.
Pic of one of the 4 bolts that hold the engine mount to the engine:
Pic of the 14 mm bolt that holds the mount to the sub frame (I reall want to cut this nut off with an angle grinder but its recessed in a hole)
How high are you guys jacking up from the oil pan the manual says no more than 7mm I think I have jacked it more like 2" still cant get it out...
every ounce counts
Hellmun
Postby Hellmun » Sun Jun 07, 2009 5:57 am
From memory, once I undid both bolts and supported the engine, I tapped the bolt on the tight side (one of the mount sides has movement to lever it up and down) to pop it out. Once I had it moving I put the other looser sides engine mount bolt back on a few turns and twisted the engine by then jacking it up. The last side was still a pain to do, I ended up grabbing my dad to lower and push the engine into alignment with the bolt hole while I watched from under. It was a really tight fit because there wasn't much movement at all in the new mounts and I remember having to physically push the whole engine down myself when the new mounts wouldn't bend. I got the Mazdaspeed racing versions which are the hardest.
Postby manga_blue » Sun Jun 07, 2009 5:30 pm
On an NA the right side mounting stud fits into a vertical slot while the left side just has a bolt hole. So when you install a motor you put the left side in first (cos it's a much tighter fit). When you take the motor off the mounts you'd usually get the right side off first.
Postby 93_Clubman » Mon Jun 08, 2009 5:09 pm
hey wun, that's some serious weight saving supporting the engine like that :P
