Oil Leak
Posted: Sat Jun 06, 2009 2:56 pm
by TieNN89
I believe I have an oil leak
And I think its coming out of the sensors
Pressure Sensor/Switch ...
You can just see the Knock sensor I think it is above it with a little oil on it as well
What do you guys think?
Are the sensors busted?
Looks like a PITA! to remove :(
Oil Leak
Posted: Sat Jun 06, 2009 3:08 pm
by de Bounce
Yep, that's a oil leak
Looks like only the one is leaking
Should be a cheap and common part
Oil Leak
Posted: Sat Jun 06, 2009 4:09 pm
by TieNN89
the one above it has oil on it as well
Oil Leak
Posted: Sat Jun 06, 2009 4:20 pm
by manga_blue
I'd be pretty surprised if an oil presuure sensor was leaking tnhrough the middle of it. Look higher.
Oil Leak
Posted: Sat Jun 06, 2009 4:33 pm
by TieNN89
manga_blue wrote:I'd be pretty surprised if an oil presuure sensor was leaking tnhrough the middle of it. Look higher.
Thats what I'm thinking
leaking thru the threads and onto the pressure sensor
but iono I can just see it
Oil Leak
Posted: Sat Jun 06, 2009 8:36 pm
by de Bounce
Looks the same as an oil pressure switch I replaced on a Corolla a few years back!
Oil leaking from the centre of the switch is not uncommon in all makes of cars.
Mazda Part No is B367–18–501 to suite a NB and should be available from Repco / Bursons or Mazda
Oil Leak
Posted: Mon Jun 08, 2009 5:12 pm
by manga_blue
OK, you live and learn. Thanks de Bounce.
