Armchair diagnosis
Posted: Mon May 25, 2009 10:05 pm
by break
Just after bouncing some ideas off others here before I get stuck pulling my car apart this weekend.
I've got an issue at the moment that is puzzling me with my '99 Mx5. I'm getting an annoying squeaking sound that increases with intensity with RPM that sounds very similar to when the wear bar on brake pads start to lightly rub the disk.
Oil levels and quality look good (only 4k since last change with Mobil 1).
The noise remains even when still left in gear, but clutch pushed in.... but the sound dimishes when the clutch is pushed in (so I'm fairly confident its the engine side of the driveline as the squeak correlates to the rpm of the motor).
If I shift the car into neutral and rev the motor the sound persists.
Sooo... what I'm left with is bearings, something is up with the flywheel or input shaft on the gearbox, or maybe even just a belt (even though it sounds a little too metallic to be a belt). I'm also told a loose manifold can give a noise similar to what I describe, and it recently had the exhaust done (full new cat back job) so I was going to check that too.
Any advice before I poke around and/or take it down to my mechanic?
Armchair diagnosis
Posted: Mon May 25, 2009 10:10 pm
by kazjim
Clutch Throwout bearing ?
Armchair diagnosis
Posted: Tue May 26, 2009 1:15 pm
by GP
+1
Armchair diagnosis
Posted: Wed May 27, 2009 3:01 pm
by ampz
Check the lower mounting bolt on your alternator.
Make sure it's tight (or even there) :oops:
I'm surprised it didn't die, but then again, it's not the original one and I don't really know where it came from but it ain't broke... :P
Armchair diagnosis
Posted: Thu May 28, 2009 4:43 pm
by break
Cheers for that suggestion about the alternator. I'll have a look at that as well.
Armchair diagnosis
Posted: Fri May 29, 2009 9:09 am
by Charlie Brown
kazjim wrote:Clutch Throwout bearing ?
+ another 1.
Can't be the alternator as pushing the clutch in doesn't effect any belts/bearing in that area.
Armchair diagnosis
Posted: Fri May 29, 2009 4:41 pm
by break
Ok, more diagnosis today helping me pinpoint it.
I wasn't feeling crash hot so stayed home and put the front end up on ramps. I pulled the entire exhaust off (bar the headers) and there was no chance to the noise (well, the noise in question).
It's since got a little louder and more consistant, and now definitely reduces in volume significantly (to the point where it almost can't be heard) when the clutch is depressed. It also sounds loudest around 2,500rpm under load.
So yeah, time to take it to a gearbox joint I think :cry:
Armchair diagnosis
Posted: Fri May 29, 2009 5:42 pm
by JBT
Try MX-5 Plus
Armchair diagnosis
Posted: Fri May 29, 2009 7:15 pm
by Jace
the previous owner of my car (who happens to be a relative) informed me that the gearbox responds very negatively to increased idling in gear with the clutch depressed (sitting in first at lights, rather than in neutral).
my car in particular has had approximately $3000 spent on the gearbox (two owners ago) to correct the clutch throw bearings.
good luck getting this sorted.
Armchair diagnosis
Posted: Fri May 29, 2009 8:42 pm
by orx626
break wrote:It's since got a little louder and more consistant, and now definitely reduces in volume significantly (to the point where it almost can't be heard) when the clutch is depressed. It also sounds loudest around 2,500rpm under load.
Trevor, it might be worth checking the oil level or even replacing the oil, and see what results.
Regards,
