Page 1 of 2
Beatrush Brass Bush
Posted: Mon May 04, 2009 1:51 am
by TieNN89
And so I decided to change the oil in the shift turret
When I took the shifter out and took the brass bush out this is what it looks like now
normal?
its from my NB8A 5 Speed which has an IL Motorsport Quick Shift Kit fitted to it
Beatrush Brass Bush
Posted: Mon May 04, 2009 1:56 am
by Okibi
Very not normal !
Beatrush Brass Bush
Posted: Mon May 04, 2009 2:00 am
by philz
Well the fact that before it was nice and smooth now it looks like its been through a cheese grater, I would say no not normal.
Beatrush Brass Bush
Posted: Mon May 04, 2009 2:02 am
by TieNN89
any idea what the hell is going on?
:S
Beatrush Brass Bush
Posted: Mon May 04, 2009 11:23 am
by sliq
what the fudge man!
have you got a quick shifter?
maybe you didn't fit the busher in properly. i remember the first time i fitted mine, it was very clunky, so i knew i had fitted it in wrong.
second time round it was as smooth as silk.
Beatrush Brass Bush
Posted: Mon May 04, 2009 2:43 pm
by Locutus
i'd better take a look at mine
Beatrush Brass Bush
Posted: Mon May 04, 2009 5:12 pm
by ampz
I wish i could find where i put mine, so I could stick it in.
Beatrush Brass Bush
Posted: Mon May 04, 2009 6:36 pm
by TieNN89
sliq wrote:what the fudge man!
:S how can you fit it wrong :S
you just put it in drop the shifter in and its all good isn't it :S
Beatrush Brass Bush
Posted: Mon May 04, 2009 7:57 pm
by wun911
I thought you had to whack it in with a hammer or something??
is there a pic of it new??
Beatrush Brass Bush
Posted: Mon May 04, 2009 8:51 pm
by TieNN89
i didn't have to wack it in with a hammer :S
plastic one yeah but not with this brass one
it was perfect fit wasn't tight fit
Beatrush Brass Bush
Posted: Mon May 04, 2009 11:16 pm
by sliq
not quite, when u stick the gear stick back in, the little notches on the the stick have to align perfectly. mine wasn't, so it sounded crunchy when i changed gears. what is when i knew the bushing would slowly wiggle out of place. when i pulled out the gearstick to check, the bushing was definitely not sitting flat.
Beatrush Brass Bush
Posted: Tue May 05, 2009 7:33 pm
by TieNN89
OVERDRAWN wrote:Hi If you have a Quickshift it would appear that it has been incorrectly fitted, ie too high and the bottom of the stick has not fully engaged in the bush
AO
hmmmm maybe I'll have to pull it out tonight and have a quick look again but I can't see how its not correctly fitted
Beatrush Brass Bush
Posted: Wed May 06, 2009 12:43 pm
by Juffa
I purchased a metal bush as part of last years group buy, can't remember if that was a beatrush or another make. It is installed in my original 5spd gearbox (no quick shift).
The first thing I noticed was that the metal bush was not a sung fit, unlike the original plastic bush, i.e. I had to drop the bush into the turrent and then insert the gear stick. Over the last month or so I have noticed that the gear changes have become very notchy. I have been meaning to check the clutch slave cylinder, as well as the new bush. After seeing the above photos I think the bush will be my priority.
Here is my thinking. If the bush is fully free floating, i.e. does not fit snugly to the ball at the end of the gear stick, could it not sit too low when compared to an original bush? If so consequently the gear stick is catching the top edge of the bush, rather than being housed inside the bush, and causing the damage. If you drained the gear box turrent of oil you maybe able to see where the bush sits in comparison to the end of the gear stick?
J
Beatrush Brass Bush
Posted: Thu May 07, 2009 12:20 am
by TieNN89
Yep I got mine from the Group Buy too its a Beatrush
My one was fitted the way you did too
Had to drop the bush into the turrent then put the gear stick back in
Yeah i was actually thinking that might be the reason why this was happening the other day as well
Let us know what your one looks like when you take a look I'm interested in seeing if yours is the same as mine or its still in perfect condition
Beatrush Brass Bush
Posted: Sat May 09, 2009 7:38 pm
by Juffa
Well. I had a chance to pull out my brass bush and took the following pics.
In my case the internal top 3mm is where the ball at the end of the gearstick comes into contact with the bush. There is also signs of wear/pitting around the inside top edge of the bush
AZNTieN, is your MX-5 a daily driver? If so it might explain why yours has worn faster than mine, as my MX-5 is a generally a weekend driver. I would not have expected the bushes to have worn so fast. I was thinking of putting the original plastic bush back in, but I have misplaced it
Might be an idea if others that purchased the bush take a look at theirs and let the forum know how their bushes are wearing to see if there is a pattern of wear. depending on OEM or Qickshift gear stick, and regular or irregular driver?
J
