HKS VPC - ECU not going closed loop
Posted: Sat May 02, 2009 11:54 pm
hi everyone,
I have a HKS VPC, I have wired it all up onto my car and checked all the signals with a multi-meter. At idle the VPC is sending about 1.3volts to the ECU and then the volts increase at rpm and throttle, hence the MAP sensor is working and the signal is being processed and sent the ECU. I understand that the AFM operates between 1 and 5 volts, so this should be fine.
However, the ECU is constantly in open loop (think I got it the right way around - closed loop is reading the O2 sensor and fluctuates) I know this from my AFR meter (jaycar), ie it is not fluctuating and just reads rich all the time, plus you can smell the fuel.
So, any thoughts on why the ECU is not happy. When I put it back to stock with the AFM, everything is okay again????
Maybe the VPC is trashed (it was second hand)
Thanks for any help!!
Si.
Si.
