SuperMazdaKart
Postby SuperMazdaKart » Thu Apr 30, 2009 5:56 pm
mx52nv
- Purple Porsche Eater
- Vehicle: Non MX-5
Postby mx52nv » Thu Apr 30, 2009 6:21 pm
rossint
Postby rossint » Thu Apr 30, 2009 6:23 pm
Very interesting stuff, thanks for posting.
Matty
Postby Matty » Thu Apr 30, 2009 6:31 pm
That testing method looks like it would be brilliant for bearing races. I'm not sure what this has to do with motor oils.
I'm sure high pressure grease, or diff oil, would give an excellent score, but I sure as hell wouldn't use it to fill my motor...
marcusus
Postby marcusus » Thu Apr 30, 2009 8:03 pm
Too much to read... what's the short version?
JBT
Postby JBT » Thu Apr 30, 2009 8:08 pm
From your signature: "The right to change our destinies lies within Us."
Recommendation: Read the information provided and make your own informed decision.
marcusus
Postby marcusus » Thu Apr 30, 2009 9:51 pm
JBT wrote:From your signature: "The right to change our destinies lies within Us."
Touche.
Still won't read it tongiht, but perhaps on the weekend when I've got a bit more time set aside for killing.
SuperMazdaKart
Postby SuperMazdaKart » Thu Apr 30, 2009 10:18 pm
marcusus wrote:Too much to read... what's the short version?
if you believe the article, it means we should be using either Royal Purple, Penrite full synthetic, or Valvoline Durablend
*shoulder shrug*
madboy
Postby madboy » Fri May 01, 2009 11:30 am
Interesting read, but I couldn't find any mention about what temperature the the oils were at when the test was done? surely this would alter results?
specially after reading the link in this thread
http://mx5cartalk.com/phpBB-3.0.2/viewtopic.php?f=29&t=35948 and his opinion that no oil is thin enough at cold start to lubricate properly
Matty
Postby Matty » Fri May 01, 2009 12:56 pm
madboy wrote:Interesting read, but I couldn't find any mention about what temperature the the oils were at when the test was done? surely this would alter results?
Exactly - I bet it was done cold. Also, the test is on brand new oil - it would be more relevant to pull oil out of an engine that has done 5000km, and see if those that performed well when new still worked, or if all the special additives had broken down and disappeared.
blackster
Postby blackster » Sat May 02, 2009 12:17 pm
I wouldnt be throwing away your current engine oil yet.
"Are engine oils created equal" it seems Street Commodores contacted manufacturer of testing equipment and they claim that the test equipment is for grease NOT oil. Street Commodore to their credit issued an apology and retraction. (search "bob is the oil guy" site for that one I'll give you the apology link.
http://www.streetforce.com.au/news/01_o ... t_oils.php
http://www.youtube.com/watch?v=n1VUxtHn7JMThis seems interesting. Anti friction metal conditioner
Previous
04' MX5 SE.
02' MX5 Classic ed.
- Vehicle: NA8 - Turbo
Postby bruce » Sat May 02, 2009 12:35 pm
Street Commodore must be edited by retards. It only took 5 minutes for this forum to see how inappropriate the testing was.
d-mag
- Road Track Rally
- Vehicle: ND - Turbo
Postby d-mag » Sat May 02, 2009 12:40 pm
bruce wrote:Street Commodore must be edited, bought and read by retards.
Fixed.
MX5 Wanted. SE or NC (forced induction preferred
Postby Mr Morlock » Thu May 14, 2009 5:08 pm
Really understanding the differences in oils I suspect eludes many of us since we are generally at the mercy of the ad men. This is a test process which does compare one to another- how relevant it might be might be questioned but it nevertheless draws a conclusion based on the same test for all. I would prefer to read a test rather than listen to someone banging on about one brand or another without any evidence or science whatsoever. For most of us if we change our oil and filter as specified it probably does not make much difference. Thanks for the post it was interesting and informative.
SuperMazdaKart
Postby SuperMazdaKart » Thu May 14, 2009 5:43 pm
yeh not a problem.
i use Penrite HPR10 semi 10w50 oil myself, so looks like i get what i paid for.
