more power, improved economy for $8
SuperMazdaKart
Postby SuperMazdaKart » Thu Apr 23, 2009 7:18 pm
Pretty much common knowledge here already but doesn't hurt to remind everyone. It's the reason why I don't like oiled filters like K&N.
You can also do cleaning of the throttle body valve & the odd spray of TB/carby cleaner into a intake vacuum pipe.
& if you believe tonites news report, the antarctic ice caps aren't melting, they're actually getting bigger.
madboy
Postby madboy » Thu Apr 23, 2009 9:26 pm
many people on this forum own many different cars that they don't wish to... disclose...so there is no need to apologise...anyway, you said it was a work car? unless your are self emplopyed, its not really yours :) and i haven't meet anyone yet who complained about driving a company car and I am sure many people here also hold the late Mr Brock in very high regard.
Good reminder tho, alot of this type of info can easily get lost in the detritus of a large forum like this...
ebola
Postby ebola » Mon May 04, 2009 9:19 pm
Slightly related...
After being defected on Sat, I removed my pod filter and returned the original air box and plumbing to its correct place. I ended up getting a very noticeable increase in power by the ummm, downgrade??? :shock:
mx5cartalk n00b
Wakefield - 1:18.62 - Standard 1990 NA6
Alex
Postby Alex » Sun May 10, 2009 5:58 pm
TheShiz2009 wrote:haha whoops, i tryed to have a go looking for these sensors and messed up the air flow meter and some other cables so the car couldnt start. its running now but only for a little while cause it keeps flooding. still any directions to where these sensors are?
It's hard to sort out something like over the net, let alone with no information on what car it is. Location could help to as someone might be close who could just drop in and take a look.
SuperMazdaKart
Postby SuperMazdaKart » Sun May 10, 2009 7:22 pm
did you undo the little metal clip on the airflow metre wiring or did the unscrew the screws on the connector method
Matty
Postby Matty » Mon May 11, 2009 6:16 pm
SuperMazdaKart wrote:did you undo the little metal clip on the airflow metre wiring or did the unscrew the screws on the connector method
I've got $10 says he did the latter, and broke the wires inside as a result.
