cam installation question
- 16bit
just wondering what I should expect to pay for cam, cam gear with cam cover mod and valve spring installation? Is there a round about figure?
- Matty
No idea, but since you have an NB, factor in a new set of shims as well...
- 16bit
where would I get this inner shim kit and how much should it be?
- 16bit
- Matty
I never said inner shim kit. whether you need that depends on your cams (particularly the lift). But since the lifters are solid you will need a shim of some description to take up the tolerance errors.
- 16bit
yep now i get it. i will send the specs to whoever installs it and get them to look after that.
