injector question
- 16bit
injector question
just wondering if the ford motorsport 440cc green top is a direct plug and play injector for a 98 model?
- zoomzoom
- Vehicle: NA6 - Turbo
injector question
Looks like they have the rectangular plugs, so you would need to change them on the loom or get an adapter.
RX7 non turbo injectors are 440cc and plug right in.
- d-mag
- Road Track Rally
- Vehicle: ND - Turbo
injector question
I was under the impression that rotary injectors have a different spray pattern to norm.
Is this the case?
Props to Blackster for the following...
Is this the case?
MX5 Wanted. SE or NC (forced induction preferred
- zoomzoom
injector question
Not as far as I am aware. They are of the same pintle type tip as the na6 injectors I replaced, as opposed to the nb injectors which have 4 little holes.
FYI the 195500-2010 injectors I have actually tested at 440cc/min
Tim
Tim
injector question
Sean wrote: As for the inejctors, the RX7 ones are DEFINATELY DIFFERENT spray pattern.
viewtopic.php?f=29&t=33021&st=0&sk=t&sd=a&start=15
- 16bit
injector question
i will not be putting rx7 injectors in. my tuner really does not like them. thanks all.
