NA6 to NA8
JMather
NA6 to NA8
Postby JMather » Sun Mar 29, 2009 9:01 pm
Ok there may be a topic but I couldn't find one. So sorry if there is one.
Oh well it's been discovered that I have the dreaded short nose crank issue! To make matters worse I snaped the bolt head off the crank centre bolt. :(
So I need a new engine, now I don't want a 1.6 I don't see much of a point (If I'm putting in the effort to put a new engine in I would rather a new, better and faster one.)
So the question is what is interchangeable between a NA6 and the NA8 (head alternator a/c exhaust manifold etc. And will I need a new ecu? Or could mine do it?
Is ther much diffrence between in stock peformance between the two?
Also where is a good place to get a 1.8?
Thanks to any and all who help.
Ps: sorry bout the spelling I'm buggered at the moment.
Boyracer
MX-5 Encyclopedia
NA6 to NA8
Postby Boyracer » Mon Mar 30, 2009 9:37 am
It's quite an easy conversion...Flyin Miata do a kit so you don't have to change computer and stuff...
Best if you call MX5mania as they have done this many times.
corners
Vehicle: ND - Supercharged
NA6 to NA8
Postby corners » Mon Mar 30, 2009 8:35 pm
Hey mate
It can be done but everything runs off 1.6 electronics.
To update to 1.8 electronics 70% of the wiring has to be changed as the 1.8 uses different sensors and coils to the 1.6
PM me if you want any more info.
Personally I would go with another 1.6
