aircon sudenly stopped working?
Posted: Tue Mar 24, 2009 5:49 pm
by 16bit
my aircon flat out does not work. I got it re gassed less than a year ago and replaced with a new compressor and pipe work. It worked the other day and just blows hot air now. Could it be a fuse? the light still comes on and it would not be a belt as I still have power steering. any ideas?
Posted: Tue Mar 24, 2009 6:29 pm
by corners
Is the compressor kicking in still?
Posted: Tue Mar 24, 2009 10:57 pm
by marcusus
When mine ran out of gas, the light stopped coming on and the compressor wouldn't run (ie no power loss, nor idle rev changes). Hopefully that info will help in diagnosis.
Posted: Wed Mar 25, 2009 8:49 am
by Garry
After looking at simple things like blown fuses and wires coming unplugged take it to an A/C place and check to see if it has any gas.
Posted: Wed Mar 25, 2009 1:38 pm
by 16bit
the light is on but I am pretty sure there is no power loss to the engine when I turn it on so is there a switch or something on the pump that could be broken?
Posted: Wed Mar 25, 2009 1:48 pm
by corners
16bit wrote:the light is on but I am pretty sure there is no power loss to the engine when I turn it on so is there a switch or something on the pump that could be broken?
On the front of the pump (Well NA anyway) there is an electric clutch perhaps that clutch isnt kicking in or the wire that controls it is loose or has become disconnected?
Posted: Wed Mar 25, 2009 2:58 pm
by wun911
I have removed AC but when I push the button the light still turns on.
Maybe a leak??
Posted: Wed Mar 25, 2009 8:58 pm
by 16bit
i am thinking it may be a loose wire - i will have a look over it and see what happens.
