Torsen 2 - Which oil?
Postby Okibi » Wed Mar 18, 2009 12:54 pm
Which oil do people recommend to put in a Mazda Torsen 2 LSD? :mrgreen:
StanTheMan
Postby StanTheMan » Wed Mar 18, 2009 12:56 pm
cool.....The NA has a torsen?
can't recall what i put in it. :oops:
Postby sliq » Wed Mar 18, 2009 1:16 pm
dave i recently had redline shockproof put into mine - it'll last the car the rest of its life.
it ought to be the same one people put in their gearboxes.
wun911
Postby wun911 » Wed Mar 18, 2009 3:17 pm
I thought it was different oil for diff and different oil for gear box??
Also any differnece between open diff and LSD diff in terms of oil??
every ounce counts
Postby sliq » Wed Mar 18, 2009 3:20 pm
lol i could be wrong - maybe it was a different grade of redline? *shrugs* i didn't do the job myself.
Postby bruce » Wed Mar 18, 2009 3:22 pm
sliq wrote:dave i recently had redline shockproof put into mine - it'll last the car the rest of its life.
Methinks it should still be changed (not that often though).
Locutus
Postby Locutus » Wed Mar 18, 2009 4:04 pm
pretty sure any GL4/GL5 gear oil is fine for the torsen. it doesn't require LSD specific oil because it's mechanical.
most gear oils are fine in both the gearbox and (mechanical) diff.
Rotary
Postby Rotary » Wed Mar 18, 2009 4:18 pm
As Above, any gear oil should do, Lightweight Shock proof is good stuff, rated strength of a 75W140 without the heavy weight
zoomzoom
Postby zoomzoom » Wed Mar 18, 2009 6:42 pm
The oil recommended by castrol is their EPX80W90, which is the same as the open centres. Only difference is the torsen takes only about a litre(tad under from memory) and the open more like 2ish.
tbro
Postby tbro » Wed Mar 18, 2009 9:16 pm
Hi Dave,
I'm using Valvoline GL4 75/90 semi synthetic, in both diff and gearbox, on the clubby.
Definiately made a lot smoother shifting and diff runs nice and cool.
Beside that, I buy in bulk for my fleet of trucks so make the decision easy!!!
Terry
wun911
Postby wun911 » Wed Mar 18, 2009 11:22 pm
I have to try this light weight oil who makes it?
every ounce counts
Postby sliq » Wed Mar 18, 2009 11:26 pm
wun911 wrote:I have to try this light weight oil who makes it?
Redline.
See here:
http://www.mx5mania.com.au/product1112.htm
Locutus
Postby Locutus » Wed Mar 18, 2009 11:37 pm
imo shockproof in the diff is overkill unless your car is putting some serious power to the ground.
sure it's the rolls royce of gear oils (in both performance AND price), but from all reports it doesn't last as long as a regular oil.
