Torque band missing 2000-3000rpm
Could it be the plug leads--how old are they?
- daffyflyer
Can you avoid it by using light throttle?
As in is there a certain amount of throttle over which it gets crap
Thats what my other car did when the plugs were flowered
Developing a Car Industry Game - Visit www.automationgame.com
White 1994 MX5 Clubman - Carco Built NA Motor - 101kw ATW @ 7500rpm
- Learner Driver
- Vehicle: ND - 2
Frm what it sunds like, mine does it too. I never thaught anything of it, cos iv never dríven a 4cyl b4 this and i thaught it was just how they r. Let me know if the tune up helps. cos if its fixable id consider it. Thanks
- daffyflyer
tassone56 wrote:Frm what it sunds like, mine does it too. I never thaught anything of it, cos iv never dríven a 4cyl b4 this and i thaught it was just how they r. Let me know if the tune up helps. cos if its fixable id consider it. Thanks
Well, it should not have much torque under about 3k, but its the variation/stuttering of torque that suggests issues.
If it turns out not to be a fault, a supercharger should help!!
- philz
- Wheel guru
what do u mean by original ones?
Original one that came with the car 5 years ago?
I would just change them + plugs, I felt a night and day difference with new ones in.
- daffyflyer
tcoo7399 wrote:The problem seems to begetting worse. Its now happening very frequently through all the gears. Over 3000rpm it smooths out a bit but is still not what it should be. I recently put in a pod filter/CAI could this be affecting the AFM?
Happens from 30% throttle or higher.
I checked the leads and they seem to be the original ones.
That sounds EXACTLY like the issue i had with bad leads and plugs, get some good quality plugs and leads, even if it doesn't fix it, its still a good thing to replace
- Caffeine
Coilpack!
