Crank pulley wobble
JMather
Crank pulley wobble
Postby JMather » Wed Mar 11, 2009 8:56 pm
my crank pulley wobbles :(
What causes this problem and how cam I fix it? Will replacing the pulley fix the problem or is this more sinister?
Thanks for all you help :D
corners
Vehicle: ND - Supercharged
Crank pulley wobble
Postby corners » Wed Mar 11, 2009 10:58 pm
You need to either take to a mechanic for further investigation or have a look yourself depending how good you are mechanically.
It is typically caused by the crank pully bolt working loose..
mx52nv
Purple Porsche Eater
Crank pulley wobble
Postby mx52nv » Wed Mar 11, 2009 11:03 pm
The infamous short nose crank problem where the keyway is worn?
Take to your local MX5 specialist (update your location and we can suggest the nearest one).
Good luck. 8)
JMather
Crank pulley wobble
Postby JMather » Sat Mar 14, 2009 5:40 pm
Updated location. the crank pully is tight. What is the short nose crank problem?
Thanks for all your help. :D
JMather
Crank pulley wobble
Postby JMather » Sat Mar 14, 2009 5:44 pm
Also is the Crank Pulley in my 1.6L the same as the 1.8L BP Engines?
Crank pulley wobble
Postby sliq » Sat Mar 14, 2009 5:52 pm
i don't see any location :frown:
mx52nv
Crank pulley wobble
Postby mx52nv » Sat Mar 14, 2009 11:28 pm
Me neither...
To the OP:
1) Update your location in your user control panel -> profile -> location: __________
2) Do a search for short nose crank using the search function. There have been many threads on the issue.
3) The B6 crank pulley is different from the BP crank pulley from memory (happy to be corrected on this if someone can confirm otherwise). :mrgreen:
JMather
Crank pulley wobble
Postby JMather » Tue Mar 17, 2009 8:18 pm
Sorry about that guys, i think i didn't press submit. everything is updated.
I was just about to get a new twin exhaust before all this too. :cry:
