Post Air Con pinging
Posted: Tue Mar 03, 2009 5:41 pm
gidday
not having much luck with my 94 1.8 NA - new radiator, new brakes etc etc, coolant boiling, sounds like a tram & brakes squeel - ahhhhhhhhhhhhhhhhhhhh (tram sound is a missing brake spring thing, squeeling is from non approved brakes). Yes I'm a pomme....
I had a very expensive service recently (actioned all above) after which I used the air con in the hot weather....then and ever since after I use the aircon I get pinging (horrible rattle) - but the pinging is non existant after I've run the car for a while without air con and put the car under load - however i'm using 98 ron fuel now which may explain the lack of ping
engineer said it could be to do with the timing not being set right or rubbish fuel? anyone been through this or have any suggestions? in general I think there is a lack of power, can really tell the difference when using differnt fuels, I'm reticent to spend more money as I think I've been ripped off by the last people who serviced it
have done 230k on the engine so maybe time to bite the bullet and get a replacement - can't afford the time off the road for a rebuild
thoughts?
thoughts?
