Probelms with AFM, wiring or ECU. NA8 (need wiring diagram)
Posted: Fri Feb 27, 2009 4:30 pm
by Okibi
CONTI wrote:Will start and run initially for about 40 sec before stalling will restart but time gets shorter, thoughts?
Sounds like something is heating up.
Perhaps it's running fine with the cold start bypass then once that switches off it's stalling.
OR ..
It could be O2 sensor related where the 02 sensor heats up then gives an error.
OR ..
temp sensor related where the coolant hits a temperature then triggers something.
Sorry these are all general thoughts and no solutions but it might help prompt someone wiser to give you a fix.
Posted: Fri Feb 27, 2009 6:26 pm
by Fatty
you might be able to find a wiring diagram here:
http://www.madracki.com/miata/wiring.html
