Filthy/calcified leads and plugs
NMX516
Postby NMX516 » Fri Feb 13, 2009 8:58 pm
Well it's not uncommon, put it that way. Not ideal either. A squirt of WD-40 into the end of the leads will help clear that up. Caused by moisture getting into the spark plug well as I understand it.
wun911
Postby wun911 » Sun Feb 15, 2009 10:45 pm
I use dielectric grease you dont need much, keeps moisture away keeps terminals clean works on the battery too.
every ounce counts
