Revs randomly going up and down
Oni
Postby Oni » Mon Feb 09, 2009 10:33 pm
Hi all,
Once again im hoping someone here can come to my rescue. I don't have a lot of info i was surprised then the below happened but its happened once before. I had been driving for about 5 min in stop and go trafic then had to merge onto the highway, so i accelerated and changed into 4th at about 4k rpm. that took me too about 3.5k rpm in forth gear. under acceleration the needle then started jumping around between say 3k rpm and 4.5k. i backed off and it stabilized and i wasn't able to reproduce it.Sorry if its posted before i wasnt able to get the search working ( a 430 error ).
Ill try get some more info if i can and post back again soon. Some reading said that it might be a bad ground. Im pretty new to cars i just learned to change my oil so any Noob friendly troubleshooting tips would be great :) oh and the car is a 1990 manual mx-5 with 190,000 k's.
thanks heaps
daffyflyer
Postby daffyflyer » Tue Feb 10, 2009 11:33 am
Are the actual revs changing (which would make you lurch horribly) or is it just the tacho going nuts?
Developing a Car Industry Game - Visit www.automationgame.com
White 1994 MX5 Clubman - Carco Built NA Motor - 101kw ATW @ 7500rpm
Postby bruce » Tue Feb 10, 2009 1:30 pm
Plug leads.
Oni
Postby Oni » Tue Feb 10, 2009 8:50 pm
Hey thanks for the replies, its just the tacho. while its doing it it still accelerates smoothly and doesn't behave any differently
daffyflyer
Postby daffyflyer » Wed Feb 11, 2009 11:04 am
Mine does this too, but not as bad.. NA tachos seem to be the worst bit of the entire car
Big G
Postby Big G » Wed Feb 11, 2009 3:19 pm
A lot of rev counter problems are caused by issues around the coil pack, the drive for the tacho is derived from the coil pack and a loose connection is often the cause
Geoff
Growing old disgracefully in Queensland
Founder of Eastern Region[HMF] Sunshine Coast Chapter.
1990 Mariner Blue Roadster
Verithin Guitars
