REplacing Na6a AFM ?
- kazjim
Just a quick one . . .
Do the Na8a and Na6a AFMs interchange ?
my Na6a one is in the big-ass air box and if i wanted to go to a cold-air setup i'd need to change this to a smaller AFM ... the Na8a one looks about right :-)
J
J
If my calculations are correct, when this baby hits eighty-eight miles per hour ... you're gonna see some serious s**t.
no they don't interchange.
you can use your na6 afm with a cold air intake, everybody else does. your afm can be detached from the airbox. have a look at all the photos of cold air intakes on this forum and you'll see what i mean.
- madboy
Fatty wrote:no they don't interchange.
can you interchange if you move to an aftermarket ECU? or would that be pointless because a MAP makes more sense?
yeah i reckon a map sensor would make more sense in that case.
or you can use an RX7 afm which is slightly larger, & transplant your NA6 internals into it to get a factory like idle.
93_Clubman wrote:or you can use an RX7 afm which is slightly larger, & transplant your NA6 internals into it to get a factory like idle.
yeah but why would you bother? the na6 afm is not restrictive in most applications, unless you have done some pretty serious mods in other areas (forced induction or fully built hi-comp atmo engine).
Fatty wrote:93_Clubman wrote:or you can use an RX7 afm which is slightly larger, & transplant your NA6 internals into it to get a factory like idle.
it's like washing & vacuuming your car - it feels faster
iirc, Matty's free flowing article mentioned some gain which was offset by an pretty ordinary idle when he replaced the NA6 AFM with an RX7 AFM without swapping the internals. I don't necessarily disagree with you, but sometimes it's the journey & sometimes it's the destination, or both
yeah , it's fun to tinker and i often fiddle with things that may end up offering no tangible benefit... but you never know until you try it out.
kazjim, you might find these useful if you're not already familiar with them:
http://autospeed.com/A_0892/page1.html
viewtopic.php?f=44&t=19458
viewtopic.php?f=44&t=19459
I've probably got the ebay page referred to in the middle thread saved somewhere so let me know if you need it - it detailed the modified RX7 AFM which was the subject of the ebay auction.
- kazjim
Thanks ! - Lots of reading there !
Will read and absorb .....
J
J
- kazjim
Fatty mentioned earlier in this thread about using a stock AFM ....
I havnt had a chance to look at mine closely (its around 1000klm south of me at the moment
Is it easy to separate from the air-box ?
J
J
- Jeo
Stupidly easy. 4? bolts from memory.
- kazjim
THanks jeo, I'll have a look on Saturday and see what pops out :-)
Might just have to go get a pod filter and try a few things out ...
J
J
Kazjim, hillsend used an 1986-1988 series 4 RX7 AFM, but according to N*Power a series 5 can also be used.
This is the one hillsend had for sale in the ebay link from his thread linked above:
QUOTE
RX7 Air Flow Meter to suit MX5 1.6
The standard AFM is very restrictive, the RX7 AFM flows 20% more air and can increase HP by as much as 7 HP.
This meter replaces the existing AFM to increase top end performance.
The stiff RX7 spring has been replaced with an MX5 spring so your mixture with not lean out at the top end and it idles perfectly with no other mods.
Comes complete with a pod filter adaptor as shown.
UNQUOTE
QUOTE
UNQUOTE
