Thanks for a great explaination Fatty, good to hear you were listening to me waffle on.
The finer points to fill in the blanks as was explained to me (and I'm still learning)
The designers make a plan or "Blueprint" of the motor.
Unfortunately, due to machining tolerences etc, the error on the design (although small) grows with every component.
For example:
One motor I built (F2T MX6) put out 137 kW atw with just a few boltons. I then got hold of some Forged pistons that, although weighing the same as the stock pistons, were match weighed to within 1 mg of the blueprint. Those and rings were the only change apart from fluids (it was pretty well maintained and had similar compression).
The power went up to 142 kW atw on the same dyno (Nizpro Bayswater)
That illustrates two things, the importance of blueprinting AND that balancing is important also as it reduces losses.
Back on the 10AE, I would say that the BP is only balanced, not blueprinted.
My machinist explained it this way. The motor would not "need" balancing as heavily as they are IF the motor was blueprinted.
The balancing the 10AE consists of 3 modifications/steps.
Firstly, the crank is very very well balanced. So good in fact the crankshaft guys spun it to 45000 rpm and said it had just a slight murmer. They took the slightest amount out of one of the counterweights and then spun it clean to 50000
They say that if the rest of the motor can handle it I could spin it at 10000 rpm quite safely. Just remember they spin the crank unloaded.
The second part of the balance is the flywheel. All BP's are balanced this way by drilling the perimeter. The 10AE's was perfect and was on the crank at 50000 rpm.
The third part of the standard 10AE balancing is to match the fly to the crank and recheck the balance.
Really though from my experience with BP's (limited as it is) there isn't that much difference as I believe the motor assy plant had really good QC and the parts were close to spec anyway.
I have weighed the 3 standard pistons that came from the old motor and they were good to within 0.5 g .... try getting that close with a Falcodoor
Sorry for digressing
Bazz
Back on topic, I always thought the 10AE was 9.5:1 ..... btw it's now 7:1
